Activity Forums Adobe Premiere Pro Apple TV Video
  • Apple TV Video
    Posted by Cliff Elliott on March 11, 2010 at 5:56 am
    Hi all, I have been trying to create a video file of one of my projects so it will run on my Apple TV but I have one small problem,
    The file i genarate which should be 16:9 is crunched up in 4:3 view in either Quicktime or on my Apple TV.
    I do not understand why this is happening as I use all the correct settings in the Adobe Media Encoder.
    The project settings in Premiere are
    Pal 720 x 576 16:9
    Pixel Aspect ratio = D1/DV Pal Widescreen 16:6 (1.422)
    25 Fps
    Encoder export settings
    Format H.264
    Preset Apple Ipod Vieo Large
    Video Codec Mainconcept H.264 Video
    TV Standard Pal
    720
    576
    25 Fps
    Aspect Ratio Widescreen 16:9
    Can some one pleas give me advise on how to over come this problem.
    Thank you.
    Regards,
    Cliff Elliott
    Bob Dix replied 16 years, 6 months ago 2 Members · 3 Replies
  • Bob Dix
    March 11, 2010 at 6:37 am
    I could be wrong, for 720p use ‘Square Pixels (1.0), in HD we use Anamorphic 1080(1.333)
    Freelance Imaging & Video
    AUSTRALIA
  • Cliff Elliott
    March 11, 2010 at 9:21 am
    Thanks Bob, that started me thinking and so I first deinterlased the video on the time line then exported it as a quicktime H.264 720P file and it works beatifully on the Apple TV.
    I suppose what I should do next is capture the original High Def video and edit as HD then deinterlace and output as 720P to see what that looks like.
    Again thanks.
    Cliff Elliott
  • Bob Dix
    March 11, 2010 at 9:30 am
    That’s good, you could use a Cineform /avi setting and get the same results.
    Good luck……………..
    AUSTRALIA
