Activity Forums Apple Final Cut Pro Legacy Apple TV HD Compatibility
  • Apple TV HD Compatibility
    Posted by Chris Babbitt on October 22, 2008 at 9:27 pm
    I am trying to make AppleTV- compatible clips using the presets in Compressor. According to Apple’s specs, the two compatible HD formats are 1280×720 @ 24 fps or 960×540 @ 29.97 fps. I can get the 960×540 to work, but the results are less than stellar. When I try to load the 1280×720 file onto the Apple TV, I get a message that the file is incompatible. Any ideas on what I might be doing wrong?
    The original file is XDCAM HQ 720p60.
    Jeremy Garchow replied 17 years, 11 months ago 3 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    October 23, 2008 at 1:36 am
    did you use the preset or make your own?
  • Chris Babbitt
    October 23, 2008 at 2:32 am
    I used the preset, but I changed the default of 960×540 to 1280×720
  • Jeremy Garchow
    October 23, 2008 at 2:45 am
    Try using the preset without touching anything.
    If you want, download this preset that I made. It works for me:
    https://rcpt.yousendit.com/617918503/81c0b4ee72d9c60b2067d95ce571ef4f
    Put it in your User Folder > LIbrary > Application Support > Compressor folder.
    Make sure you quit Compressor before adding anything to that folder.
    Jeremy
  • Chris Babbitt
    October 23, 2008 at 3:50 am
    If I don’t change anything, I get 960×540. That’s not HD.
  • Chris Babbitt
    October 23, 2008 at 4:09 am
    Jeremy,
    I’m encoding right now using your preset. Technically, it should not work, because the spec says that for 1280×720, the frame rate needs to be 24 fps, and yours is 59.94. I tried that already, and it didn’t work for me. I’ll let you know how it works out. Thanks for your help.
  • Jeremy Garchow
    October 23, 2008 at 4:13 am
    GIve it a shot.
    I forgot, most of the stuff we do is 23.98. I think the frame rate is set to ‘current’.
    Jeremy
  • Chris Babbitt
    October 23, 2008 at 4:37 am
    Your preset must be radically different from the Apple preset, because it’s taking forever to encode a 5 min. piece.
  • Jeremy Garchow
    October 23, 2008 at 4:49 am
    What kind of computer?
  • Jeremy Garchow
    October 23, 2008 at 4:59 am
    YOu can also set an in and an out in compressor for 10 seconds or so to see if it even works.
  • Arnljot Bringedal
    October 23, 2008 at 9:25 am
    I simply use visualhub.
    Works like a charm.
    I rarely use compressor for AppleTV encoding…..
    *** Norwegian videojournalist & Editor***
