Activity Forums Apple Motion apple speed comparision. The video card or the chip
  • apple speed comparision. The video card or the chip
    Posted by Peter on May 13, 2005 at 4:12 pm
    Hello all,
    I have a dual 2.5 with 3.5 gigs of ram, I also have a dual 2.7 with 4 gigs of ram. I run the same project on the 2.7 and it runs anout 10 to 14 frames faster on the real time play back and when running simple movements and it runs 5 to 8 frames faster where a particale is involved. Is it the chip or the video card. Can 1/2 gig of ram realy make that much difference in playback?? They are both tested on the same external hard drive.
    thanks all
    Bill Mcguire replied 21 years, 3 months ago 4 Members · 5 Replies
  • Noah Kadner
    May 13, 2005 at 4:22 pm
    It’s the video card. Read:
    https://www.barefeats.com/motion.html
  • Peter
    May 13, 2005 at 4:41 pm
    Great link, thank you
  • Bill Mcguire
    May 14, 2005 at 12:52 am
    I read an article at the Motion 2 support site today that lowering the resolution in M2 will speed up the “real time”. I wonder if it will be anywhere close to the reverse ratio (1/2 resolution equals 2 times speed increase)…
  • Richard Harrington
    May 14, 2005 at 2:26 pm
    Actually Half resolution should generate a FOUR times boost.
    Half the width and half the height is a 1/4th of the pixels beinf rendered
    So if that were the case…. SWEET
  • Bill Mcguire
    May 14, 2005 at 6:06 pm
    Of course, after adding the extra effects possible with the lower resolutions, the net gain for me will probably be zero… but during those fleeting in between moments… WOW
