Activity Forums Apple Final Cut Pro Legacy apple r not rendering selection anymore
  • apple r not rendering selection anymore
    Posted by Jim Finn on December 28, 2007 at 4:04 am
    Somehow my selections are no longer rendering. i can only render ALL or the audio but i can not use the apple R which is a pain. I restarted my computer after throwing out my preferences, but that has never affected it in the past. Any ideas. Something simple i’m missing i hope. I am using FCS 2 on a octocore MACpro
    Jim Finn replied 18 years, 8 months ago 3 Members · 4 Replies
  • Neil Ryan
    December 28, 2007 at 8:25 am
    Checked the settings which determine WHAT gets rendered with Command+R ?
    It may have changed …
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
  • Jim Finn
    December 28, 2007 at 7:41 pm
    Command R is still set for render selection. Render selection does not work at all. When i hit render selection it does nothing. THe computer will only render all for some reason.
    MACPRO Octocore
    Sony HDV-V1U 24p
  • Adam Taylor
    December 29, 2007 at 1:16 am
    what neil means is to check that the types of rendering you want to happen when you press apple-r have a check mark next to them. If they don’t then select it and the mark will appear (you may need to check it several times to get all the check marks you need)
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
  • Jim Finn
    December 29, 2007 at 7:34 am
    Thank you! It took me a while to get it but it finally got through my fat skull!
    MACPRO Octocore
    Sony HDV-V1U 24p
