Activity Forums Apple Final Cut Pro Legacy apple proress line 21 artifact
  • apple proress line 21 artifact
    Posted by Marcus Ionis on May 1, 2008 at 9:08 pm
    We received a SD 720×480 Apple ProRess file, which needed to go out to Digibeta tape. Nothing too out of the ordinary except an unusual black checkered pattern on Line 21 coming out of the KONA3 card. I defaulted with FCP color bars and the artifact was still visible. When I switched Uncompress 10bit in my Easy Setup, the problem was gone.
    I’ve contacted AJA support, whom where very helpful. Unfortunately, it appeared to be more of an FCP/QT issue instead. We down graded my driver to version 4.0 because of the particular version of QT we were using. We still had the same problem.
    I then decided to upgrade my QT to 7.4.5 and FCP 6.0.3. Again, the problem is still there.
    Currently we are rendering the file as Uncompress 10bit to resolve this artifact.
    My question to the forum “gods” are:
    1) Has any one encountered this before?
    2) If so, what was your solution?
    3) If you haven’t come across this issue, then could you perform a test and post your findings on the forum.
    I hope this is just an isolated issue and not a bigger problem.
    Thank you for your time
    Marcus
    OS 10.4.11
    FCP 6.0.3
    QT 7.4.5
    KONA3 drive 5.1
    Intel Dual Core Processor
    4 GB of RAM
    Marcus Ionis
    Marcus Ionis replied 18 years, 4 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    May 1, 2008 at 9:14 pm
    I think your ProRes file should be 720×486, not 480.
    Jeremy
  • Joe Paolo
    May 1, 2008 at 10:00 pm
    Line 21 is a common place for closed captioning.
    joe
  • Marcus Ionis
    May 1, 2008 at 11:34 pm
    Hey Jeremy
    That was it!!! 720×480 is not supported for Apple ProRes.
    Thanks for your help.
    Marcus Ionis
