Activity Forums Adobe Premiere Pro Apple ProRes on a PC
  • Apple ProRes on a PC
    Posted by Matt Lee on August 8, 2007 at 12:07 am
    We are a cross platform post production facility running mostly Apple Final Cut. However we have a PC set up to do DVD authoring and video compression. Is there a way to get an Apple ProRes 422 QuickTime into the PC realm? I don’t have the newest version of Premiere installed yet on our PC, but I assume that Premiere only supports the ProRes Codec on the Mac. Any insight??
    -Matt
    Matt Lee replied 17 years, 6 months ago 4 Members · 4 Replies
  • John Ladle
    August 8, 2007 at 12:49 am
    CS3 appears to only support ProRes on the mac only when FCS 2 is installed.
  • Alex Udell
    August 9, 2007 at 3:39 pm
    Ahh yes the open platform which is FCP….except DVCPRO HD and Pro Rez…
    hmmm
    Those codecs wil likely only be installed is FC is installed on a mac (best guess)..once installed, then you can use the media in any QT compliant application on that Mac.
    So for PC usage….Me thinks an export of material to a standardized codec would be in oder to facilitate DVD authoring on a PC….
    Best guess…
    Alex
  • John Kennedy
    March 10, 2009 at 3:04 pm
  • Matt Lee
    March 10, 2009 at 7:52 pm
    Thanks for following up on this….I certainly didn’t. Thank you for the link, but a couple weeks back we tried opening a ProRes422 file on the PC and everything worked just fine. I assume it was included in a QuickTime update from Apple.
    Premiere Pro CS4 plays back the ProRes files without rendering….sweet
    -Matt Lee
