Activity Forums Media 100 Apple ProRes 422
  • Apple ProRes 422
    Posted by Gerry Condez on March 12, 2012 at 5:21 pm
    Hi, just uploaded version 2.1 and would like to try it on OS 10.7.2. Tried to import clips from a folder with clips from canon dslr. Upon using import option > 1080i 29.29 >OPTION> the ProRez 422 can’t be selected. Why?
    Floh Peters replied 14 years, 5 months ago 2 Members · 3 Replies
  • Floh Peters
    March 12, 2012 at 6:08 pm
    Do you have the ProRes codec installed? Here is a guide on how to install them on a system without FCP.
  • Gerry Condez
    March 12, 2012 at 9:39 pm
    Hi Floh, Thanks. It worked great. Also if possible,
    I’m wondering why are the clips darker once imported?
    Any way to adjust while batch importing clips?
    Any reason why its happening? I still have my other setup
    running with kona 3 and getting darker clips, Its
    Version 1.6 I thought it will change somehow. BTW
    clips coming from canon dslr.
  • Floh Peters
    March 13, 2012 at 12:22 am
    In Suite 2.0 and up (I believe) there is an option in the import dialog to import in Computer or Video range. Most likely your clips are in Computer range (if they come from DSLR at least). Earlier versions always imported in Video range, which increases the contrast.
