Activity Forums Adobe Premiere Pro Apple ProRes 422 won’t import into Premiere Pro CS6
  • Apple ProRes 422 won’t import into Premiere Pro CS6
    Posted by Daniel Neutzsky-wulff on March 10, 2013 at 3:54 pm
    I am on Windows 8 with Premiere Pro CS6 installed.
    I have a .mov file that won’t import into Premiere Pro CS6. Upon import it says “Unsupported format or damaged file.” The file plays fine in VLC-player, but not in QuickTime and I can’t open it with MPEG Steamclip either.
    The info from VLC-player:
    Type: Video
    Codec: Apple ProRes 422 (apcn)
    Language: English
    Resolution: 1920×1080
    FPS: 25
    Decoded format: Planar 4:2:2 YUV 10-bit LE
    Type: Sound
    Codec: PCM S16 LE (sowt)
    Language: English
    Channels: Stereo
    Samplefrequence: 48000 Hz
    Bit pr. sample: 16
    Any suggestions?
    Tero Ahlfors replied 13 years, 6 months ago 2 Members · 5 Replies
  • Tero Ahlfors
    March 10, 2013 at 4:11 pm
  • Daniel Neutzsky-wulff
    March 10, 2013 at 5:04 pm
    Yeah, it says that I already have a later version of the Decoder installed. I was just told the footage was shot on:
    AG-HMC 151 Panasonic
  • Tero Ahlfors
    March 10, 2013 at 7:16 pm
    Well that camera does not shoot in Prores so it has been probably transcoded at some point.
    March 10, 2013 at 7:44 pm
    I suspected the same. They probably used Log & Transfer to transcode the footage on import, since I found all of the footage in the Capture Scratch folder in the project.
    The project was originally cut on Final Cut Pro on Mac and the editor backed out and I was handed over a half finished documentary. It was a god awful mess to begin with. I managed to clean up the project and export an XML, but I’ve had a lot of problems getting it into Premiere Pro CS6 on my PC.
    I tried doing the same on a Mac and the project imported without the same issues. I don’t really know where to go from here since I can’t edit the documentary on the Mac. I just tried it out on a friends Mac.
    Am I missing some sort of codec?
  • Tero Ahlfors
    March 10, 2013 at 7:57 pm
    The Log and Transfer might do something different to the file. I’ve had some files from FCP that just don’t work on Windows.
