Activity Forums Apple Final Cut Pro Legacy Apple ProRes 422 file extension
  • Apple ProRes 422 file extension
    Posted by Wes Koetje on May 4, 2008 at 3:30 am
    I was doing some organizing of contents of my hard drives and realized that my ProRes clips do not have a file extensions, and it isn’t hidden in the “get info” window either, is this a new practice from apple, just not assigning file extensions. A cataloging software I use doesn’t want to recognize it and was wondering if anyone else had encountered this previously. I have added an screen shot to help explain.
    Ron Priest replied 16 years, 11 months ago 4 Members · 6 Replies
  • Rafael Amador
    May 4, 2008 at 4:45 am
    Wes,
    This have been changing with the different FC versions. FC 6.0.3 sets the extension.
    Also the FC movies are set to be open with FC. In the screen shoot that you send I can see that you have the file to be open with QT Player. I guess you are with FC5.1.x
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Wes Koetje
    May 4, 2008 at 2:50 pm
    Well, maybe my copy of FC 6.0.3 is not functioning properly then. Do you know if there is a preference I can set somewhere to have the extensions be in place?
  • Rafael Amador
    May 4, 2008 at 3:03 pm
    [Wes Koetje] ” a preference I can set somewhere to have the extensions be in place?”
    No really.
    This may b something related with the File Finder Info. Do you use DiskWarrior?
    JVC DTV-17″
  • Wes Koetje
    May 5, 2008 at 2:47 pm
    No, no disk warrior, Its not a big deal I was just trying to figure out this little quirk, I found a way to work with what I have, Thanks for responding.
  • Michael Bloodgood
    May 5, 2008 at 5:40 pm
    This has nothing to do with FCP and everything to do with OSX. Leopard reduced (although not completely eliminated) the requirement of extensions on all files. It’s beginning to use logs to identify files instead of extensions. Different versions of 10.5 will have different extension requirements and to make things even more confusing, it isn’t the same across the board. 10.5.3 will have different requirements than 10.5.2.
    As you have figured out, you’ll just have to find a workaround
  • Ron Priest
    October 2, 2009 at 11:48 pm
    Hi Rafael
    I use Disk Warrior, I was wondering what your suggestion was?
    Ron Priest
    Videographer
    Louisville, KY
