Activity › Forums › Apple Final Cut Pro Legacy › Apple Pro Res Question;
  • Apple Pro Res Question;
    Posted by Jonny Cates on August 19, 2013 at 10:18 pm
    I have a ton of files to convert to Pro Res, all 1920×1080 HD, but shot with (3) different cameras. I used Streamclip to do a test on one file that was 45.4 mb originally. After the 422 conversion, that same file now becomes 363.3mb! That 8 times bigger! I have used this program before, but that seems awfully big to me.
    Is this size growth correct? Am I clicking or selecting something wrong in the 422 choices? Under the 422 selection, there are two choices that are identical, but I don’t know the difference between them….
    Jonny Cates
    Shane Ross replied 13 years, 1 month ago 2 Members · 4 Replies
  • Shane Ross
    August 19, 2013 at 10:32 pm
    [Jonny Cates] “Is this size growth correct?”
    Most likely.
    1 hour of ProRes 422 1920×1080 29.97fps = 75.3GB
    1 hour of ProRes HQ 1920×1080 29.97fps = 112.4GB
    1 hour of ProRes LT 1920×1080 29.97fps = 52.6GB
    If the frame rate is lower, say 23.98, then the file size will be lower:
    1 hour of ProRes 422 1920×1080 23.98fps = 60.4GB
    How long of a clip do you have that’s 363MB? The only way I get something that small is if I choose ProRes Proxy, and the clip is one min long 1080p 23.98. One min of ProRes 422 1080i 29.97 is 1.3GB.
    Shane
    Little Frog Post
  • Jonny Cates
    August 20, 2013 at 8:25 am
    Shane… the clip I was testing is 10 seconds long. It’s size before conversion is 45.4MB. After, 363MB.
    Original clip info…
    Dimensions: 1920 x 1080
    Codecs: H.264, AAC, two channels
    Color Profile: HD (1-1-1)
    Duration: 00:10
    Audio Channels: 2
    Total bit rate: 35,350
    Movie Information: JVC
    FPS on camera was 60i
    Jonny Cates
  • Jonny Cates
    August 20, 2013 at 8:28 am
    Thanks for the info Dave. I see yet another, external hard drive in my future.
    Jonny Cates
  • Shane Ross
    August 20, 2013 at 8:38 am
    Yup…all very normal. Bigger hard drives are in order.
    Shane
    Little Frog Post
