Activity Forums Apple Final Cut Pro Legacy Apple Pro Res (LT) requires render.
  • Apple Pro Res (LT) requires render.
    Posted by Andre Morton on April 6, 2011 at 2:56 pm
    Working with AF-100 footage that has been transcoded to Apple Pro Res standard and Apple Pro Res (LT).
    (Media managers were changed mid shoot and the second DIT suggested AVCCAM was best converted to LT for FCP workflow.)
    The standard footage drops into the timeline and is ready to go, The (LT) footage needs to be rendered.
    I’ve checked all of the sequence and clip settings everything matches except for the (LT).
    I’ve tried creating a new sequence and dropping the LT footage and it stills needs to be rendered.
    Normally i’d render and move on but I’m dealing with about 300 gigs of LT footage!
    Any thoughts or help would be greatly appreciated.
    Andre
    Shane Ross replied 15 years, 5 months ago 4 Members · 3 Replies
  • David Roth weiss
    April 6, 2011 at 3:04 pm
    Did you check the audio to make sure the LT is 48khz?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Steve Eisen
    April 6, 2011 at 3:07 pm
    If you have a ProRes Sequence, then by all means the ProRes LT needs to be rendered when on the same timeline as ProRes footage.
    What I would do is re transfer the footage from the originals. It will make your workflow much easier. You’re only talking a couple hours of time that will save you in the long run.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    April 6, 2011 at 4:37 pm
    Well, the footage should show up with the bright green render bar, meaning you can edit just fine without that much quality loss in viewing, and no dropped frames. Just have to render when you are done.
    But yes, whenever you have ANY other codec that is even slightly different than the sequence, you will have a render bar. Doesn’t mean you HAVE to render while you are editing. YOu can do it later.
    Shane
