Activity › Forums › AJA Video Systems › Apple Pro-Res HQ 1920X1080 as a RECORDING codec ?
  • Jeremy Garchow
    January 24, 2008 at 5:20 pm
    No. This stuff was actually SD that I tested, shot with an SDX900 @ 24p. I then took a few of the raw clips, setup a Compressor preset, let it run and a few minutes later I had 24p clips. It will work the same on 1080 clips
  • Pierre
    January 24, 2008 at 5:22 pm
    got it. cool.
    How did the footage compare to regular DVCPRO-50 SD footage directly out of the SDX900 ?
  • Jeremy Garchow
    January 24, 2008 at 5:41 pm
    I have never pulled an easier key. I have yet to do an HD shoot that would allow on set capture, but the next time I will definitely be capturing straight out to disk and by passing the camera codec, although we still run tape backup for assurance.
    Jeremy
  • David Chai
    January 26, 2008 at 3:46 am
    Definitely go with Prores HQ, we used to use DVCPRO HD but there would be softness introduced from the scaling to 1280 x 1080. The Pro Res is a lot sharper and gradations definitely are smoother.
    David Chai.
    David Chai
    Director . Camera . Editor
    http://www.davidchai.com
    dc@davidchai.com
    212 363 0159
  • Sean Oneil
    February 7, 2008 at 3:24 am
    [Jeremy Garchow] “Compressor has a reverse telecine option in it now. I think it automatically detects the cadence and removes PD automatically. I think.”
    Say what!?! I’m gonna have to check this out.
    Sean
  • Jeremy Garchow
    February 7, 2008 at 3:46 am
    Yes, it’s in the deinterlace drop down in the frame controls tab. All my tests look great so far. You can batch it all without the A frame fiasco.
    Jeremy
  • Sean Oneil
    February 7, 2008 at 5:10 am
    [Jeremy Garchow] “Yes, it’s in the deinterlace drop down in the frame controls tab. All my tests look great so far. You can batch it all without the A frame fiasco”
    Sweet, I’m checking it out tomorrow. I did read here though that it doesn’t work with the new Kona drivers for Leopard. But I’m on Tiger still so I’ll check it out.
    Sean
  • Jeremy Garchow
    February 7, 2008 at 2:25 pm
    What doesn’t work? Compressor?
  • Sean Oneil
    February 7, 2008 at 6:09 pm
    Ugghhh. You’re gonna make me find the link. Hold on…
    Here, it was Apple discussions, not the Cow:
    https://discussions.apple.com/thread.jspa?messageID=6487028&#6487028
    Sean
  • Jeremy Garchow
    February 7, 2008 at 6:40 pm
    Hmm, sounds suspicious to me. I am still on Tigey too. It works with AJA Kona 3 installed.
Page 2 of 3
