Activity Forums Apple Motion Apple Motion Video Output
  • Apple Motion Video Output
    Posted by Matthew Riggieri on July 9, 2009 at 7:07 pm
    Hello All
    I am having a weird issue when using the video output in Motion 3.0.2. On a dual-dual core 3Ghz with BlackMagic Extreme HD card on a 720p30 (square pixel) project using any and all RGB video output selections.
    The issue is that when looking at it on my client monitor and reference monitor it is showing me more than the actual canvas. and won’t grow to the full frame. I see additional area around everything i make, like it is showing me the outside areas of my working canvas.
    any thoughts?
    Matt Riggieri
    Digital Cave Media
    Matthew Riggieri replied 17 years, 2 months ago 3 Members · 3 Replies
  • Peter Wiggins
    July 10, 2009 at 3:09 pm
    Have you checked the output settings?
    Peter
  • Andrew Pasternak
    July 14, 2009 at 8:08 pm
    Yeah I would check your render output options like Peter suggested. Make sure they are set to the same dimensions that your project is set to. That would be my first inclination. Also maybe try to render out using Apple Pro Res 422 if that doesn’t work. I’ve had similar issues using BlackMagic.
  • Matthew Riggieri
    July 14, 2009 at 8:23 pm
    Figured it out.
    There is a setting in the view menu called Show Full View Area. You must have that unselected fot proper output.
    Matt
