Activity › Forums › Apple Final Cut Pro › Apple has to fix this ASAP
  • Apple has to fix this ASAP
    Posted by Robert Bracken on March 13, 2012 at 5:07 pm
    Whenever I add a transition to titles it affects the video below it by making the transition full screen.
    I know I’m supposed to make the a compound clip but that makes my job harder when I need frame accurate editing and I have to keep going into the compound clip and backing back out to check my work.
    I know how to right click the transition to uncheck “transition to/from black” but what was once easy in 7 is now difficult in X.
    Robert Bracken replied 14 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • T. Payton
    March 13, 2012 at 8:11 pm
    The behavior you are seeing is actually completely dependent on how the transition was created. Ripple for example will effect the entire frame. Cross dissolve will not. Depending on the settings “slide” will or will not include the background clip.
    What specific transition are you using, can you give a screen shot of what you are trying to accomplish? I’m sure we can figure it out.
    T. Payton
    OneCreative, Albuquerque
  • Ben Scott
    March 13, 2012 at 8:37 pm
    found the same thing myself
    in fact try adding composite modes in with compound clips and you see similar mess.
    earlier version of fcpx was doing transitions and rendering very odd
    the transitions are poorly implemented
  • T. Payton
    March 13, 2012 at 8:43 pm
    Can you clarify, do you mean adding transitions on composite modes of compound clips?
    T. Payton
  • Bill Davis
    March 13, 2012 at 9:28 pm
    Aren’t all the “transitions” in X just constructs built in Motion code?
    As such, if you don’t like what they do – can’t you just go into Motion and re-craft them work precisely the way you prefer?
    All the titling works that way – are the transitions any different?
    “Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
  • T. Payton
    March 13, 2012 at 9:47 pm
    Hi Bill – actually they “look” like they are all done in motion, but there are few you can’t “open a copy in motion”. Slide and Page Curl for example. 🙁
    Although there are definitely some gotchas with transitions in FCP X and they are far from perfect, but simply the concept of having editable and built-your-own transitions is incredible. If you ever tried to create an alpha transition in FCP 7 you will be in awe of the power and simplicity of FCP X and Motion.
    T. Payton
  • Bill Davis
    March 13, 2012 at 10:34 pm
    [T. Payton] ” If you ever tried to create an alpha transition in FCP 7 you will be in awe of the power and simplicity of FCP X and Motion.
    Oh I am.
    I’ve done three “kinetic type” projects in motion and I’ve seen first hand how deep the program is.
    But for all the power, it’s still “reasonably” approachable given time and patience.
    TO the OP the point is that you can’t call it the programs fault if it doesn’t do something precisely the way you want that something done – provided the program provides you the tools to customize things.
    Put another way, not being able to do things is not the same as not caring enough to spend the time learning the tools provided. And having those tools does kinda blunt that criticism, IMO.
  • Robert Bracken
    March 14, 2012 at 3:40 am
    Yep. Good call.
  • Robert Bracken
    June 11, 2012 at 8:56 pm
    The slide transition works the best.
    It’s hit or miss if a transition on the text layer will affect those below.
