Activity › Forums › Apple Final Cut Pro › APPLE FCPX and move from AVCHD to 4K
Mark Raudonis replied 10 years, 4 months ago 7 Members · 11 Replies
Mark Raudonis
April 13, 2016 at 9:23 pm[Jeff Kirkland] “Personally, I think HDR is a way bigger deal than any resolution increase.”
I agree, Jeff.
If you’ve ever seen HDR playing next to standard HD (or 4k) the difference is IMMEDIATELY apparent.
That difference WILL sell more flat panels. Kinda like the diff between Standard def 4:3 and HD 16:9.You immediately knew the HD was better. You can see it.
Plain old 4k is NOT much different beyond 9 feet. Adding HDR means you can see the diff from across the street. Your neighbors will see the difference, and you don’t even need to invite them in!
Conclusion: HDR WILL drive 4K conversion. 8K is still a parlor trick.
Just my thoughts.
