Activity › Forums › Adobe Encore DVD › Apple, Encore and the right Blu Ray DVD burner
Tyler Back replied 16 years, 10 months ago 7 Members · 17 Replies
Terry Flaxton
January 25, 2009 at 6:08 pmDoh! Of course – thanks again for the point about re-write-ables and single record DVD’s.
So I have some swf’s which I want to import into encore but that only takes FLV’s or F4V’s – right ? So how do I turn an swf into either of those two file systems (I search around the net but all I seem to get is windows solutions). Seems like CS4 desn’t take swf’s and output into either – unless I’m missing something. Am I?
A long term DP – likes 35mm and HD equally – changing with digital media – Began as a commercials editor !
Joe Bowden
January 25, 2009 at 7:46 pm[Terry Flaxton] ” So how do I turn an swf into either of those two file systems (I search around the net but all I seem to get is windows solutions).”
You could try this in Flash. But if you have Flash, you could export an AVI or MOV that Encore would probably prefer.
Terry Flaxton
January 25, 2009 at 11:08 pmThanks for the help.
Terry Flaxton
January 26, 2009 at 5:48 pmSo, happily I went off and tried a solution suggested by Warren- that is, getting a Panasonic SW-5583 Blu-Ray – of course these units are not available in the UK yet !!!
Has anyone tried the LG GGW-H20L Internal on a MAC – this one I can get easily and cheaply
Thank you for everyone that’s already replied.
Erik Scairpon
February 3, 2009 at 10:30 pmI am also curious as to the performance and satisfaction with this drive. Anyone have an experience to relate?
Thanks in advance,
Erik -
Andrew Ford
March 12, 2009 at 7:02 pmI second the quality of the LaCie d2 external Blu-ray drive, especially if you work on a Mac.
https://www.bhphotovideo.com/c/product/602325-REG/LaCie_301856U_d2_Blu_ray_Drive.html
I have authored over 50 Blu-ray discs with this drive since getting it in Jan and I’ve had no problems. I use the FW400 connection and the burn time is fast. The portability is great when I’m on the road. I’ve used TDK, Verbatim, and Sony discs, both BD-R and BD-RE, 25 and 50gb, and no problems across the board. Letting Encore transcode can be painfully slow, so I use Sorenson instead to get a better result in a little less time.
Tyler Back
November 22, 2009 at 12:43 amAndrew, are you able to give any insight on your workflow to creating so many successful Blu-ray discs? I am getting ready to do my first BD and I am starting to get overwhelmed with all the different methods.
