Activity › Forums › Compression Techniques › Apple Compressor–Stereo is not Stereo
  • Apple Compressor–Stereo is not Stereo
    Posted by David Rowan on March 11, 2009 at 11:28 pm
    I need to convert my finished edit to an MPEG file, with embedded audio.
    I use the “MPEG 2–>Program Stream” setting.
    I am happy with the results, except:
    Its taking the two stereo tracks that I export and mixing them together. The new file has stereo audio, but its just a mix of what was originally two independant tracks.
    I cannot find anywhere in the inspector a place to make sure that the audio gets seperated properly. Where do I look?
    Compressor 3.0.5 on MacPro dual quad core. OS 10.5.6. The original files are Standard Def IMX files, I export them from the timeline with some tracks panned left and some panned right, and they are, indeed, stereo.
    Daniel Low replied 17 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    March 12, 2009 at 7:49 am
    [David Rowan] “The new file has stereo audio, but its just a mix of what was originally two independant tracks. “
    Check with the manual – that’s what’s supposed to happen.
    Fonts are like cologne:
    A bad choice speaks louder than a good one.
