Activity › Forums › Compression Techniques › Apple compressor – no interface shows
  • Apple compressor – no interface shows
    Posted by Stu Aull on October 8, 2010 at 2:25 am
    Just reloaded my FCS2 – 6.0.5 into my new 12core Mac-
    Compressor menu BAR opens up when I open the App but NO layout. I can manually open each window, but can’t seem to get it to load a video clip. Before, I could just drag a clip onto the icon and it would open Compressor, all ready to go.
    Layouts menu offers nothing that sets up all the windows.
    ran a repair program “Compressor Repair” – no joy.
    Compressor 3.0.1
    FCS2
    Snow leopard 10.6.4
    14GB ram
    apologies if this is incorrect forum! Did not see one for this App.
    Stu Aull
    Alaska
    Stu Aull replied 15 years, 11 months ago 3 Members · 6 Replies
  • Andrew Saliga
    October 8, 2010 at 4:40 pm
    Yeah, I hate Compressor.
    Sorry, my suggestion was Compressor Repair. Is your OS up to date, rebooted your computer? 🙂
    Andrew Saliga
    I/O Specialist/Assistant Editor
    Steelehouse Productions
    http://www.steelehouse.com
  • Jon Chappell
    October 8, 2010 at 5:40 pm
    Have you tried going to ~/Library/Application Support/Compressor/Layouts and deleting the file Compressor.saved.moduleLayout? It’s worth a try.
    Let me know if it works for you and I’ll add it to the next version of Compressor Repair.
    My software:
    FCS Maintenance Pack – Tools to keep Final Cut Studio running smoothly and fix problems when they arise
    FCP Versioner – Backs up Final Cut Pro projects to XML and creates changelists for each revision
    More tools…
  • Stu Aull
    October 8, 2010 at 7:25 pm
    Thanks guys-
    Tried the Compressor Repair app – no joy
    Tried dumping the Layout file – no joy
    Reloaded Compressor off install disc-
    Its Up!
    so – fingers crossed, I have at least an interface now 🙂
    Again my thanks for stepping up
    regards
    Stu Aull
    Alaska
  • Stu Aull
    October 8, 2010 at 10:48 pm
    Okaaay-
    So 1st time I drag in a clip to Compressor, as soon as I select a codec, the program crashes!
    tried the Repair App again, no joy.
    All this after a fresh install of Compressor ( 3.0.1 plus 3.0.5 update) off the install disc. Man, all these years of using Comp in my G5 tower w no probs, now in the newly-minted 12core its crash-o-rama
    any thoughts?
    Stu Aull
    12core
    14Gb Ram
    FSC 2
  • Jon Chappell
    October 8, 2010 at 11:28 pm
    After the 12-cores came out, Apple released an update for Final Cut Pro 7 to address incompatibilities caused by the fact that Final Cut Studio was designed for a maximum of 8 cores. I would assume that this incompatibility remains in Final Cut Pro 6 which has not been updated. It may therefore be necessary to upgrade to FCP 7 ($299) to fix these issues.
    My software:
    More tools…
  • Stu Aull
    October 9, 2010 at 7:24 am
    Hi Jon-
    yes, FCS 3 is in the works, since I can’t go on like this!
    besides, all the core power and not using latest/greatest is sorta silly 😉
    Will be looking at your FCP service software too I think.
    cheers
    Stu Aull
    Alaska
