Activity Forums Compression Techniques Apple Compressor – MPEG2-Program Stream
  • Apple Compressor – MPEG2-Program Stream
    Posted by Matthew Ziegele on November 29, 2011 at 2:37 pm
    Hi all
    Im not sure if anyone else is having this issue i am seeing with compressor 3.5.3
    We have ProResHQq clips made from Final Cut 7.0.3 that are NTSC 29.97 and contain timecode.
    When using the default Compressor setting for MPEG2-Program streams, it states that it will use the “Start timecode from Source” – when the file is done, and i check it -the timecode starts at 00:00:00
    instead of the 00:59:55;00 of the actual clip.
    How can i get the MPEG2 PS file to contain the correct timecode
    Mac OSX 10.6.8
    Brad Wright replied 14 years, 9 months ago 3 Members · 2 Replies
  • Brad Elliott
    November 30, 2011 at 7:58 pm
    I have not been able to have Compressor read meta data from a file and then translate that to a window burn.
    To my knowledge Compressor’s window burn feature only starts from zero.
    If someone makes timecode notes from the file that starts at zero you can just jump into your sequence 14:37 from the head and all should be well presuming the notes are right to begin with.
    The only other option is to use the TC reader filter and render your sequence in FC with a window burn.
    Nest your sequence in a a new sequence and then apply the filter to the nest. Make sure your new sequence starts at the appropriate TC.
  • Brad Wright
    December 1, 2011 at 3:35 pm
    I think Program Stream timecode isn’t defined all that well defined as a standard. I would recommend doing a window burn out of Final Cut Pro, if you can live with that.
    Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
