Activity Forums Compression Techniques Apple Compressor leaves temp files when encoding to an SMB volume
  • Apple Compressor leaves temp files when encoding to an SMB volume
    Posted by Jeffrey Di lullo on February 5, 2018 at 2:40 pm
    The title really says it all.
    When I have an SMB volume as a destination, Apple Compressor leaves the temp file after the encoding is finished. The temp files are the same size as the encoded files which range from 50 to 300 MB. I am able to delete the files through the SMB connection from my iMac, I don’t need to log directly into server.
    I’m using Compressor 4.3.2 on an iMac running 10.12.6. I am encoding to a Mac Pro (old cheese grater) that is running OSX server.
    Anyone else experiencing this?
    Jeffrey Di Lullo
    jeffedits.com
    Jeffrey Di lullo replied 8 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
