Activity Forums Compression Techniques Apple Compressor “Background Process”
  • Apple Compressor “Background Process”
    Posted by Maxjavier on August 13, 2005 at 12:07 am
    I import a QT into Apple Compressor, choose Settings and Destinations and when I hit Submit, the following warning shows up “Unable to connect to background process” and it won’t let me go any further.
    What does that mean?
    Mariusz replied 21 years ago 2 Members · 1 Reply
  • Mariusz
    August 17, 2005 at 3:20 am
    I will reply because I just had this problem. There is some info on Apple Support page but it did not help in my case. I had to manually remove everything from my computer that said “compressor” or “Qmaster” using spotlight.
    Then I reinstalled Compressor with Qmaster and it works fine now. Good luck.
    Mariusz
