Activity Forums Compression Techniques Apple compressor and error “0”
  • Apple compressor and error “0”
    Posted by Steve Foley on July 28, 2006 at 6:54 pm
    Hi all
    OK — here’s what I’ve got: brand spankin new G5 dual core 2.3. — totally virgin top to bottom. Updated all the way. Brand new install of Final Cut Studio crossgrade — the latest and greatest — also updated all the way. Everything here is squeaky clean — no stray code floating around anywhere from any previous applications.
    SO — the problem is the (I have discovered) dirty little Apple secret that Compressor 2.1.whatever does not like dual processor machines — every time I try to encode something to mpeg2 it goes a while and then gives me the “quicktime error 0” message.
    I’ve done quite a bit of digging around in these message boards and have only found some older posts claiming that a certain Apple download patch will allow you to shut off one processor — and then Compressor will work properly. I tried that and no go.
    Is this still the latest attempt at a solution? Those posts were several months old — hard to believe Apple hasn’t addressed the issue properly since then. Am I missing something?? Has this problem been corrected — and maybe it’s some other conlict I’m having?
    Only other thing on my system at this time is a couple of Lacie big disk extremes — but they don’t “seem” to be creating any disturbance in the Compressor force.
    What gives??
    Steve
    PS — this thread has been kicking around the Apple boards for a few days — everyone is baffled. This problem is very common but so far nobody has the magic bullet for it.
    Schackman Films replied 19 years, 11 months ago 3 Members · 2 Replies
  • Rich Rubasch
    July 30, 2006 at 1:56 am
    What are you encoding? Are you using Ref clips or self contained? Are the clips on the Lacie and are you creating the MPEG-2 back to the Lacie? Did you try sending the MPEG-2 to the internal drive? Did you delete the Compressor prefs (most likely you did). Is it a preset you are using to encode or have you created a new setting? CBR or VBR?
    Rich Rubasch
    Tilt Media
  • Schackman Films
    October 2, 2006 at 12:43 pm
    Was there a resolution to this issue. I have the same problem? Let me know if you found out anything.
