[Alan Stephens] “I actually got one of the mp4 presets in v 3 to work”
Those aren’t H.264. They’re the much older and inferior MPEG4 part 2 spec. I’d use MPEGStreamClip before using those.
[Alan Stephens] “It is rather foreign to work in but I guess I can get used to it if the upgrade it to the level of tools we have come to depend on.”
He mentioned he was very happy with the Multicam implementation and apparently broadcast monitoring was working well too. It seems as though there may be improvements on the server and san front that will make viable in a facility environment. There’s a lot of little workarounds one has to do now which really slows one down. Those have to be improved.
From the point of view as a compressionist, I like that I can edit H.264 .mp4 directly and although it can transcode to ProRes in the background, I haven’t had to do that. There’s been a few times where I’ve gotten from a client is the H.264 .mp4 from a server side recording of a live stream and have had to turn that around as an edit ASAP. Of course a facility level NLE needs a bit more than that.
