Activity Forums Compression Techniques Apple Compressor 16:9 framesize ?
  • Apple Compressor 16:9 framesize ?
    Posted by Sieger Duinkerken on October 17, 2008 at 2:48 pm
    i’m a bit confused about 16:9 framesizes.
    my dvpal file is 720×576 anamorphic.
    when I use Compressor to convert it to MPEG2 16:9, the file is 720×404. I lose pixels.
    shouldn’t it still be 720×576 pixels (and afterwords stretched in the dvd or whatever-player) ?
    Compression documentation doesn’t make this quite clear for me, so I hope someone could tell me how it works 🙂 thanks!
    Ed Dooley replied 17 years, 11 months ago 3 Members · 5 Replies
  • Ed Dooley
    October 17, 2008 at 2:57 pm
    The trick is to not believe what QT is telling you. It looks at the PAR flags and says it’s 720×404 when in fact it’s 720×480 anamorphic. Look at it through MPEGStreamclip (a free app if you don’t have it), and it will show you that it’s correct.
    Ed
  • Sieger Duinkerken
    October 17, 2008 at 3:00 pm
    wow, thanks for your quick reply! 🙂
  • Ed Dooley
    October 17, 2008 at 3:02 pm
    You’re welcome!
  • Daniel Low
    October 17, 2008 at 4:05 pm
    Actually it would be 720×576 if you use the (superior) PAL format rather than the 720×480 of NTSC.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Ed Dooley
    October 17, 2008 at 4:09 pm
    Yes, that’s true, but same point, same result. I’m so U.S. centric. 🙂
    Ed
    [Daniel Low] “Actually it would be 720×576 if you use the (superior) PAL format rather than the 720×480 of NTSC.
