Activity Forums Apple Final Cut Pro Legacy Apple Color renamed files and now XML won’t sync up with footage. Is there a workaround?
  • Apple Color renamed files and now XML won’t sync up with footage. Is there a workaround?
    Posted by Pierre on August 3, 2011 at 8:46 pm
    I did things backwards I’m sure.
    I’ve got a finished cut in FCP. The finished cut has gone back and forth between FCP and Color several times. As a result all of the clips were renamed in Color (original clip names don’t match)… so when I export an XML and attempt to reconnect that XML with the original uncolored files FCP can’t find files or hangs at 48% ?
    Help !!
    Jeremy Garchow replied 15 years, 1 month ago 2 Members · 5 Replies
  • Jeremy Garchow
    August 3, 2011 at 9:26 pm
    I’m confused at to what you are trying to do. Did you delete the original sequence, that is, the one you first sent to Color? That should be what you want.
  • Pierre
    August 3, 2011 at 9:32 pm
    essentially, after color I then started to recut based on the new colored sequence because I couldn’t stand to look at the ungraded material. I know. Really stupid mistake… I’m not an editor.
    trying to dig myself out of this one.
  • Jeremy Garchow
    August 3, 2011 at 9:37 pm
    You are going to have to force reconnect by turning off the option to “match by name” and then point FCP to the original file.
  • Pierre
    August 3, 2011 at 9:44 pm
    I tried that and at first FCP progress bar looks good and then stops at 48%. I’ve tried several times and waited at least ten minutes. Is it supposed to take that long?
    thank you !
  • Jeremy Garchow
    August 3, 2011 at 9:50 pm
    [Michael Pierre] “I’ve tried several times and waited at least ten minutes. Is it supposed to take that long?”
    Open the Activity Monitor app, is FCP “not responding”?
    Jeremy
