Activity Forums Blackmagic Design Apple Color +Intensity Pro+HDMI+Plasma?
  • Apple Color +Intensity Pro+HDMI+Plasma?
    Posted by Sam Roberts on February 11, 2010 at 2:16 am
    Hi. I am looking for a low cost solution for grading with Apple Color in HD using an HDMI output to my Panasonic plasma monitor from an i/o card in the PCIe slot of my MacPro. Will the Blackmagic Intensity pro do the job?
    I already have AJA’s ioHD which will not output an HD signal from Color but does everything else i/o-wise.
    Sam Roberts replied 16 years, 7 months ago 2 Members · 3 Replies
  • Margus Voll
    February 12, 2010 at 10:39 am
    Hi.
    How you plan to calibrate your system so you get what is that you correct?
    It seems to me bit tricky to grade wo sdi output.
    Margus
    https://iconstudios.eu
  • Sam Roberts
    February 13, 2010 at 12:53 pm
    The Blackmagic will be an interim step until I have the budget for a high end SDI monitor. All my clients will watch my projects on TV anyway and I am not doing film out. The plasma has been lined up using a DVD made for that purpose and looks very good, surprisingly good actually. Are you using this card? How do you like it? The HDMI out quality is good?
  • Sam Roberts
    February 13, 2010 at 8:39 pm
    Nobody using this card to output from Color?
