Activity › Forums › Adobe After Effects › Apple clone stamp offset data across entire shot
  • Apple clone stamp offset data across entire shot
    Posted by Jim Bachalo on May 16, 2014 at 12:51 pm
    ok, I have a tracking shot and I need to remove some tracks on the floor
    Clone stamp tool is probably the best option BUT, how do I paint-clone just 1 frame but get it to apply across the entire shot?
    i.e. for each frame, the clone-paint offset should be identical.
    This is the shot
    https://vimeo.com/94716098
    pw music
    You should follow me on Twitter here. My latest work
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    John Cuevas replied 12 years, 4 months ago 2 Members · 3 Replies
  • John Cuevas
    May 17, 2014 at 9:45 pm
    Use your clone stamp and create your clean trackless pic. Precomp the clean plate and use a Layer > Time > Freeze Frame. Then you need to track, apply tracking data to a null, parent the clean track to the null, and then mask…or something along those lines.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jim Bachalo
    May 18, 2014 at 1:17 pm
    Yes, thanks. That SEEMS to be the correct approach for this shot.
    However, in this case there is SO much scale change via perspective that my clean plate gets enlarged way too much at the beginning of the dolly, appearing pixelated
  • John Cuevas
    May 19, 2014 at 6:02 pm
    On the other board, I mentioned you might want to try the CC Wire Removal effect, I took a still of your video and it seemed to work okay.
    Otherwise, if you can make your video available to be downloaded, I could try some other methods(play around) and see what works and doesn’t.
    Thinkck.com
