Activity › Forums › Blackmagic Design › Apple 30″ Monitors
  • Apple 30″ Monitors
    Posted by Matthew Ingram on February 12, 2006 at 2:36 pm
    Got some cash I was considering splurging on one of these.
    I have an Nvdia Ultra 6800 so theoretically my ‘ol Dual 2.5 will take it.
    BUT
    Are there problems with expecting the Mac to power such a huge amount of screen real estate?
    Would my Black Magic Extreme’s performance be adversely affected?
    (ps Hope no-one minds but I’m going to cross-post this in the FCP and AE forums….need all the feedback I can get)
    Jonathan Smiles replied 20 years, 7 months ago 5 Members · 9 Replies
  • 9 Replies
  • Bob Zelin
    February 12, 2006 at 4:00 pm
    that is the point of the hi performance graphics card. It has everything required to drive the 30″ DVI monitor, and does not bog down computer resources, or other PCI cards. As you may know, it is difficult to find an NVidia 6800 card these days.
    Plug it in, you will be fine.
    Bob Zelin
  • Matthew Ingram
    February 12, 2006 at 4:07 pm
    thanks bob,
    just thought it sensible to check.
    difficult to find an nvidia 6800 ultra? why so? because apple is now offering the higher-range nvidia cards as a built-to-order? or is this a pci-bus thing?
  • Neil Sadwelkar
    February 13, 2006 at 3:36 am
    In case this helps. I am running 3 Dual 2.5 GHz setups 2 with BM HDPro cards, and one with BM Decklink Vanilla. All three have 30″ displays running off that ‘special nVidia’. And all three have been running since Nov 2004. One does Shake only (2k mostly), and the other two do FCP only – SD mostly rarely HD.
    Not a hitch.
    I also have three other systems without that nVidia and 30″ displays but with BM cards installed. So I can say for certain that 30″ displays with BM cards are not particuarly different from those without 30″ displays as far as reliability is concerned.
    And now I’m about to get two more – Quads this time – all will have 30″ displays and BM cards, maybe even MB Ext.
    Go for it.
    Neil
    14 BM cards old.
  • Matthew Ingram
    February 13, 2006 at 11:14 am
    blimey. thanks very much neil, thats well and truly tried and tested.
    still curious as to why this nVidia (which I bought with an eye on my maya) is so ‘special’?
  • Bob Zelin
    February 14, 2006 at 3:09 am
    The NVidia 6800 is a DVI-D card, which is required for the 30″ DVI monitor from Apple. The 23″ monitors are DVI-I, and the graphics cards like the standard ATI 9650 only have DVI-I ports on them, so they cannot drive a DVI-D monitor. This is the reason that AJA HDP and Blackmagic HD Link cannot display properly on an Apple 30″ Cinema display – both products have DVI-I ports on them, designed for the Apple 23″ Cinema display with DVI-I, or similar monitors (like the Dell and HP) that also have DVI-I.
    Bob Zelin
  • Margus Voll
    February 15, 2006 at 6:33 am
    Hi.
    A bit offtopic but can enyone compare Dell vs MAC monitors.
    As I see here in my location Dell gives same performance but 25% less price.
    Dell 30″ (11ms) seems even faster than Apple’s 30″
    Eny comments on that ?
    I’m trying to set up such setup but have not desided which monitor.
    I have PC stations.
    Margus.
  • Bob Zelin
    February 16, 2006 at 3:13 pm
    your PC stations better have DVI-D monitor cards to drive these monitors.
    A standard DVI (DVI-I) card will not drive a 30″ monitor.
    bob Zelin
  • Jonathan Smiles
    February 16, 2006 at 3:22 pm
    Hi All,
    DVI-I means analogue and digital on the same connector.
    DVI-D means digital only it will normally be single link
    DVI-D Dual Link is what you need for the 30inch Display.
    Jonathan Smiles
    Managing Director/CEO
    Digital Safari Ltd
    UK – Specialist Reseller
    dCinema – HD – SD
    https://www.digitalsafari.co.uk
  • Jonathan Smiles
    February 16, 2006 at 3:48 pm
    Good guide to DVI here
    https://www.datapro.net/techinfo/dvi_info.html
    Jonathan Smiles
    Digital Safari Ltd
    dCinema – HD – SD
