Activity Forums Adobe After Effects Applcation display query
  • Applcation display query
    Posted by Chris Brett on November 20, 2012 at 1:44 pm
    Hi there……
    ……. anybody know please if its possible to vary the size of the overall control panel so that the AE application displays other than at full screen size ?
    Chris Brett
    Walter Soyka replied 13 years, 9 months ago 2 Members · 5 Replies
  • Walter Soyka
    November 20, 2012 at 2:19 pm
    You can size the Ae application frame any way you’d like. Drag the lower-right corner.
    You can also drag docked windows out of the application frame and have them as floating windows.
    Walter Soyka
  • Chris Brett
    November 20, 2012 at 2:52 pm
    Hi Walter – thanks for your speedy reply …
    … thats pretty much what I thought but am wondering if there is a prefs setting or someting that gets it to match the screen resolution ….
    ………… the problem I am having ATM is that the app is displaying bigger than the physical screen size so I cant get hold of the bottom corner to change anything —
    —— chris —
  • Chris Brett
    November 20, 2012 at 3:03 pm
    Hi Walter
    —— once again many thanks — its now sorted …..
    The answer is to open AE — lower screen resolution via ‘start/desktop’ which enables display of one of the corners which can then be used to re-size as you described – then put screen res back again and close AE which then opens at the right size……
    …… not that you will ever need to know ! ! !
    ————– all the best —–chris —
  • Walter Soyka
    November 20, 2012 at 3:06 pm
    You’re on a Mac, right, Chris? Try clicking the Maximize button (the +, third dot in in the upper left corner of the Ae window).
    Walter Soyka
  • Walter Soyka
    November 20, 2012 at 3:11 pm
    [chris brett] “The answer is to open AE — lower screen resolution via ‘start/desktop’ which enables display of one of the corners which can then be used to re-size as you described – then put screen res back again and close AE which then opens at the right size……
    …… not that you will ever need to know ! ! ! “
    I should have known: see https://forums.creativecow.net/thread/2/974280 for a blast from the past.
    Glad you’re sorted, and thanks for responding with the fix!
    Walter Soyka
