Activity › Forums › DaVinci Resolve › appending nodes
appending nodes
Posted by Aurie Anden on October 10, 2010 at 6:54 pmA question:
Anyone know a quick way to append color correction from a still?
…without having to add nodes in the target clip and dragging the corrections inside?
…or without having to drag all the nodes i want from the still to the target clip’s graph?
Any shortcuts for this I don’t know of?
Margus Voll replied 15 years, 11 months ago 4 Members · 6 Replies -
Ola Haldor voll
October 11, 2010 at 12:31 amIf I understand your question correct, try Middle mouse clicking on a still..
Aurie Anden
October 11, 2010 at 7:07 amhi ola.
the middle mouse button applies the color correction from the still…thereby replacing whatever nodes i already have in my target clip.
what i want to do is append/add the nodes from the still to the target clip without touching my existing nodes.
thanks
Ola Haldor voll
October 11, 2010 at 11:04 amRight click -> View Nodes (or something along those lines). Then you can drag-and-drop from the window that appears onto the node window.
Christopher Tay
October 11, 2010 at 11:12 amHi Aurie,
Do you mean appending all the nodes from the Stills to the current shot starting from the last node ?
-chrispy
Aurie Anden
October 11, 2010 at 1:44 pmyes chrispy! that’s it! 🙂
ola, i wanted to know if there’s an easier way to do that. i find dragging and dropping rather time consuming.
Margus Voll
October 11, 2010 at 8:29 pmI had the exact need last week.
I did first run to balance shots on first node.
Afterwards i did want to append “look” so that the first node was left as it is after
primary run.I did not dig manual too much but i managed it to just drag and drop.
I just got 3 minute music video and it was not hard. With full feature this possibility would be
real timesaver.How is others managing this task ?
Margus
