Activity Forums Adobe After Effects Expressions Append text style settings to existing source text expression
  • Append text style settings to existing source text expression
    Posted by Leo Mazzei on September 18, 2023 at 12:21 am
    Hello!
    I have the following expression applied to the source text property of a layer:
    var src = thisComp.layer("INPUT").text.sourceText;
    var key1 = src.split(" ")[0];
    var key2 = src.split(" ")[1]; // used in a different layer
    var key3 = src.split(" ")[2]; // used in a different layer
    key1
    I have three layers set-up like this.
    I want to be able to control all layer’s font size with a single slider, so I thought of using
    var fSize = thisComp.layer("Controllers").effect("Font Size")(1); // Slider
    style.setFontSize(fSize)
    However, I don’t know how or if it is even possible to append this to my original expression.
    Thank you
    Brie Clayton replied 2 years, 12 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 18, 2023 at 12:36 am
    Try it this way:
    var txt = key1
    style.setText(txt).setFontSize(fSize)
  • Leo Mazzei
    September 18, 2023 at 3:45 am
    Using setText() did the trick.
    Thank you as always, Dan!
  • Brie Clayton
    September 18, 2023 at 2:53 pm
    Thanks for your solve, Dan!
