Activity Forums Maxon Cinema 4D Append layer name to render filename
  • Append layer name to render filename
    Posted by Paul Roper on September 10, 2013 at 3:29 pm
    Hello,
    I’m hoping there’s a way to insert layer names (or any other variables) in the filename of a C4D render, like you can in Maya (just add to the filename in Maya). I have a bunch of layers I need to output (separately) and hope I can get C4D to name the files automatically, rather than me having to name each one. But I can’t find anything like this in the “help” or online, so I’m not too hopeful.
    Any thoughts, anyone?
    Many thanks,
    Paul
    Paul Roper replied 13 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 10, 2013 at 6:35 pm
    The multi-pass save options give you the option to automatically append the pass name to the end of the rendered sequence. Otherwise there isn’t much control built in. You can’t have custom names for separate layers (aside from the above) and you can’t actually name your object buffers.
    This plugin seems to resolve those issues and also provide some nice options for organizing output: https://www.rendertom.com/plugins/renomi/
  • Paul Roper
    September 11, 2013 at 8:47 am
    Thanks – I’ll take a look at that plugin.
    – Paul
