Activity Forums Adobe After Effects Expressions Append a text file with expressions.
  • Append a text file with expressions.
    Posted by George Felix on July 6, 2017 at 6:08 am
    I got a hard one for you.
    I know that with the expression
    $.evalFile (myPath);
    You can read a text file, but is there a way to append an existing text file on your computer or to create a new text file ?
    I have a text file called data.txt which I read the variables with the values in the file. If I want to do some calculations in one of my composition and store the result in a text file, either this one or another one so I can latter call the results.
    Can this be done? Basically I am asking if there is a write or print command for an external text file.
    Dan Ebberts
    replied 9 years, 2 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    July 6, 2017 at 6:22 am
    There’s no way to write or save data with an expression.
    Dan
  • George Felix
    July 6, 2017 at 6:29 am
    Thank you
    One more questions, can you read data from a MS Access database with expressions and if so, what would the code be.
    George
  • Dan Ebberts
    July 6, 2017 at 12:46 pm
    The only way an expression can read an external file is with the $.evalFile() hack, which means that the contents of the file has to be text formatted as valid JavaScript. I don’t know the file format of MS Access, but I’m guessing it’s not likely that it would work.
    Dan
