Appearing Dots
I have this map that I attached to this message. What I was trying to make this points fade in randomly using any effects but at the end I did it manually, dot by dot. Now what I am trying to do is basically the same but with the dots popping up from the background, increasing and decreasing the sizes. I want to do it in two different ways, the first one randomly and the second one as a wave coming in diagonal from the top and left. If anyone knows how to do it with an effects or using expressions it would be great.
