Activity › Forums › Adobe After Effects › Apparition Mist in AE
  • Apparition Mist in AE
    Posted by Skaterknight on October 12, 2006 at 7:11 pm
    Ok, so i used Fractal Noise to create a sort of mist for an apparition that t i’m crcreating in After Effects. My question is, how do i make the black part of the effect transparent so that when i bring in a video clip of the person to key out to become tehe apparition, i can overlay the effect and use multiply to make the mist a part of the person.
    To key out the person i’m shooting him against a solid background and keying out the color. Once i do that i plan to lower the opacity of the clip to make him appear ghostlike.
    I chose fractal noise because with some playing around i managed to create this cool looking mist twirly effect, i just have to get rid of that black background in order for you to see the person.
    Any advice would be great, thanks!
    Skaterknight replied 19 years, 11 months ago 6 Members · 7 Replies
  • 7 Replies
  • Colin Braley
    October 12, 2006 at 8:21 pm
    There are many ways to make the black part of the fractal noise transparent, but I would say the easiest woul be to pre-comp it, and apply the “screen” transfer mode to the precomp.
    ~Colin
  • Aharon Rabinowitz
    October 13, 2006 at 12:41 am
    I don’t believe you actually need to precomp it for that. You can just set the layers transfer mode to screen.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Colin Braley
    October 13, 2006 at 5:08 am
    Your right Aharon….since Blending modes are the last thing applied when you render (masks, effects, transforms, blend modes) no precomp necessary.
    ~Colin
  • Mylenium
    October 13, 2006 at 6:10 am
    Either use blend modes or get an unmultiplying plugin such as XMult, Knoll Unmult or Walker Effects Alpha tools. A cheap way would be to use a duplicate of the layer as a luma matte.
    Mylenium
    [Pour Myl
  • Reloaded
    October 13, 2006 at 11:48 am
    Yes, they are all right.
    And if after you apply the Screen mode there is still some black edge, you can apply Remove Color to eliminate it.
  • Tony Kloiber
    October 13, 2006 at 2:39 pm
    Use a copy of your keyed person (a precomp) as a matte for the Mist layer to constrain the mist to the Ghost’s body.
    TonyTony
  • Skaterknight
    October 13, 2006 at 4:57 pm
    The screen blending mode worked great, as well as the color key to get rid of the excess black. I even discovered on another post where you teach how to make an “invisible man” that if you use displacement mapping i could adjust the mist over the “ghost” even more.
    I really appreciate the advice guys!
