Activity › Forums › Adobe Premiere Pro › APP CS 6 will only render out 24 bytes
  • APP CS 6 will only render out 24 bytes
    Posted by Chris St-amour on December 9, 2012 at 11:36 pm
    Hi all,
    An issue I’ve recently come across while exporting H.264 video is that APP will only render out 24 bytes. Render time is normal (about an hour for ~700 mb), and I have watched the rendered file grow in size throughout the render process. As soon as the render finishes, it compiles the audio and video together to create a single 24 byte file, NOT a ~700 mb file. I have also been having issues with importing/editing CS5.5 projects, giving me an error that I’m missing plug ins or presets (this has been reported in a few other threads, but none of the solutions have worked for me). I believe that these two issues are connected to each other, but I have no idea as to why this has suddenly started to happen. I have reinstalled CS6 to no avail. Any help would be much appreciated.
    Additional: I did manage to get a render to 400 mb (out of ~700 mb), but only half of the video was rendered. The video in question is approximately two minutes long. I am rendering 1280p video, and if rendered in small portions (<30 seconds) there doesn’t seem to be any issues with the final output coming out to be 24 bytes.
    Chris St-amour replied 12 years, 9 months ago 3 Members · 3 Replies
  • Dennis Radeke
    December 10, 2012 at 11:15 am
  • Ryan Laughlin
    December 5, 2013 at 4:26 am
    Did you ever get this figured out? I am having this exact same problem and can’t seem to resolve it. It is only when I export large files. When I do short 1 min clips, the export is perfect, but when I do large multi-Gig exports, it fails. It’s like the info gets trashed all at once at the end. Please help!
  • Chris St-amour
    December 7, 2013 at 12:12 pm
    Hey Ryan,
    I was never able to find a solution to this issue. I was lucky enough to have a backup laptop that I ended up having to transfer all of my files over and rendering from there. I believe I also had to do a clean re-install of APP before the problem was resolved (if memory serves correct)
