Activity Forums Adobe After Effects apllying different colours to an animated path
  • apllying different colours to an animated path
    Posted by Joey Campbell on November 13, 2013 at 10:30 am
    Hi – is it possible to apply two different colours to a paths stroke…so that when the path line is animated the colours move with the parts of the path they are applied to ? (I tried using the gradient stroke on a shape layer but it doesn’t seem to work well when i move the point on the path to animate them).
    Joey Campbell replied 12 years, 10 months ago 2 Members · 2 Replies
  • Kevin Camp
    November 14, 2013 at 10:17 pm
    you may be able to do what you are looking for with 2 instances of the stroke effect.
    if you create a mask path on a layer, add the stroke effect and set the paint style to ‘on transparent’ (set the size and color as desired).
    then duplicate that stroke effect on the same layer, but change the color and set the style to ‘on original’. now if the change the start or end values of the second stroke effect, it should give you two colors on the same path.
    does that do what you need?
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Joey Campbell
    November 15, 2013 at 1:08 pm
    Hi Kevin – I decided to do it in c4d instead with an animated spline with a spline wrap and offset the movement.
    Thanks anyway
    Joey
