apch codec in vegas
Guys
I am having trouble with one particular kind of QT file (.mov) that I have been sent via ftp sites. These are very hi res broadcast quality music videos that we insert into our show weekly. (Syndicated Crook and Chase) Vegas 10 won’t play them. It is apch.
Here are the specs on the file. I have been told that there is no way for Vegas to read this kind of file. Is that correct?
General
Complete name : C:Documents and Settingsasburyuser1DesktopTemproddythompson@gmail.comChris Young _Neon_ ProResHQ#6326.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 5.78 GiB
Duration : 4mn 48s
Overall bit rate mode : Variable
Overall bit rate : 172 Mbps
Encoded date : UTC 2012-05-04 21:10:50
Tagged date : UTC 2012-05-04 21:11:53
Writing library : Apple QuickTime
Media/UUID : B1497A26-F973-4674-8D38-D0166B8400DFVideo
Format : ProRes
Format profile : High
Codec ID : apch
Duration : 4mn 48s
Bit rate mode : Variable
Bit rate : 171 Mbps
Width : 1 888 pixels
Original width : 1 920 pixels
Height : 1 062 pixels
Original height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 2.839
Stream size : 5.72 GiB (99%)
Language : English
Color primaries : BT.709-2, SMPTE 274M, SMPTE 296M
Transfer characteristics : BT.709-2, SMPTE 170M, SMPTE 274M, SMPTE 293M, SMPTE 296M
Matrix coefficients : BT.709-2, SMPTE 274M, SMPTE 296MAudio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 4mn 48s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 52.8 MiB (1%)
Language : English
Tagged date : UTC 2012-05-04 21:11:53Menu
Duration : 4mn 48s
Language : English
Encoded date : UTC 2012-05-04 21:11:53
