Activity Forums Apple Final Cut Pro Legacy Aoutosave Problem
  • Aoutosave Problem
    Posted by Niti Shah on January 22, 2008 at 6:13 am
    Hello
    Aoutosave is not making copies as set in user preferences. It just makes copies randomly. I have done all the software updated as recomended. So many times when fcp quits or hags it results in to lost of hours of work. Its happening with fcp 5.1 and 6 too.
    Anybody with same problem? Any suggestions?
    Regards
    Niti
    Macpro 2.66, OS 10.4.11, FCP 5.1.4, 6.0.2
    Jim Dodson replied 18 years, 7 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    January 22, 2008 at 1:52 pm
    It’s not a rampant problem, so it’s more likely your system’s installation causing you the problems… or media files that are corrupt somehow…
    Post more about your workflow, and how long it’s been since you rebuilt your startup disk from the ground up…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Andreas Karoliussen
    January 22, 2008 at 2:30 pm
    What drive are your autosave set to?
    I’m working on a Xsan, and with autosave set to the Xsan Ive seen the same problem. With the autosave folder set to the local disk it behaves nice.
    Andreas
  • Jim Dodson
    January 29, 2008 at 10:31 pm
    I lost a day’s work because I had multiple projects open and it only autosaved the one project that was “in the foreground”, if you will (i.e. the project whose bin was currently chosen).
    Uggh!
    FCP 6.0.2
    Intel
    Jim Dodson
    8 Core Intel — Mac – OSX
