Activity Forums Maxon Cinema 4D AO Causing Weird Artifacts
  • AO Causing Weird Artifacts
    Posted by Ryan Paterson on March 20, 2016 at 4:13 pm
    Hi, project file attached. AO is causing weird triangular artifacts in my render. It’s a converted CAD file so the mesh is weird, is that the problem? How can I fix it? I don’t even know how to spot bad topology so any resources or advice would be very helpful. Thanks!
    9898_strapaoissue.zip
    Ryan Paterson replied 10 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 20, 2016 at 4:29 pm
    I think the problem is caused by the Normals tag on the strap object. The tag essentially bakes in the polygon normal direction, but you’re deforming the object so the normals are wrong. Try deleting the tag and set the angle in the Phong tag to around 20.
  • Ryan Paterson
    March 21, 2016 at 5:26 pm
    Nice! That did the trick, I also eliminated some rogue vertices that I think were also confusing things
