Activity › Forums › Adobe After Effects › Anyway, to fix crappy footage?
Posted by Marinos Ziakas on July 2, 2016 at 1:55 pmI used Neat Video plug-in and High Pass filter. Still the exposure is super low because of that we have “Dancing” dark pixels in the edges of the video….and i lost much of the sharpness because of neat video PI.
https://www.youtube.com/watch?v=NKJhmar7E8o&feature=youtu.be
I am sorry. I am thinking of using VHS distorion but i think is going to make this worse.
Is there a way to fix this or to add some sort of distorion around the edges so it will look that this crappy footage was intentional? Help.
Marinos Ziakas replied 10 years, 1 month ago 2 Members · 8 Replies -
Kalleheikki Kannisto
July 3, 2016 at 6:41 amAre you talking about the TV screen shots or the entire film?
I can’t really see the “dancing dark pixels” problem. I see YouTube compression artifacts.
Since you’ve already put it through Neat Video, there’s not much more you can do for the image quality. While it gets rid of the noise, it also gets rid of other details. That’s pretty much unavoidable. If the main problem is the darkness of the footage, try adjusting the brightness with a curves adjustment first, before you put it through the plug-in.
I’ve had good results with Re:Vision Deflicker, but that’s another investment.
Perhaps you could do an overall treatment that gave it apparent quality. A duplicate of the layer with a large-radius (20-40) gaussian blur and 10-20% opacity softens things out. Adding grain back in gives it a film look.
The darkness of the footage didn’t really bother me. I just got the feeling it was night time. So maybe the easiest solution would be to emphasize the night-time and claustrophobic feel with vignetted edges and a bit of a spot-light effect in the center.
Marinos Ziakas
July 3, 2016 at 10:18 amThank you really for the answer. i was talking about the entire film.
I don’t know where to start; i can use the Re:vision deflicker but i don’t know how.
Should i use it with the overall treatment that you mentioned?
I thought about vignetted edges as well. Thanks.
July 3, 2016 at 1:37 pmI assume you’ve already come a long way from the original footage, so I don’t know how much this will help…
I would try this on one piece of the original footage and see if it is worth the trouble to apply it to all:
1) Take your original footage and curve it lighter with a luma curve.
2) Run that footage through Neat Video to get rid of the noise
3) (Maybe) Run the resulting footage through Deflicker to try and get rid of the remaining flicker (I don’t know how much Deflicker can do with an already fixed footage. You’ll just have to try and see.)
4) Add a vignetted edge.
5) (Maybe) Add a spotlight-looking radial gradient in the center (subtle)
6) Add an adjustment layer with gaussian blur at large radius and at low opacity
7) Add a bit of film grain back in to compensate for all lack of grain
Marinos Ziakas
July 3, 2016 at 6:19 pmThanks for the help, i have tried everything except 3D spotlight and vignette . I think the result is almost the same. Thanks anyway.
July 5, 2016 at 9:10 amCouple of other thoughts:
– Desaturate footage to even out color noise.
– Channel Combiner with the setting of to Green to Lightness; green channel has the best detail.
(- Warp stabilizer to get smooth out unwanted camera shake.)
July 5, 2016 at 9:58 am -
July 5, 2016 at 1:09 pm -
Marinos Ziakas
July 11, 2016 at 11:29 amSorry i couldn’t asnwer but your trick seem to work. Thank you so much. I will keep it in mind next time if i screw up..
