Activity Forums DaVinci Resolve Anyway to disable adding a keyframe when a node is pasted into another shot?
  • Anyway to disable adding a keyframe when a node is pasted into another shot?
    Posted by Brandon Thomas on December 27, 2011 at 5:39 pm
    When I copy a node from one shot and paste it to another, it adds a keyframe on that node. Is there anyway to disable this?
    Makes my life complicated when I need to render out with handles..
    Resolve 8.1.1
    10.6.8
    Brandon Thomas replied 14 years ago 4 Members · 4 Replies
  • Alexandre Cristófaro
    May 1, 2012 at 11:28 pm
    anyone?! Having the same problem here
  • Knut Jansohn
    May 2, 2012 at 8:41 am
    Maybe auto keyframing enabled unintentionally?
    Never had that issue.
    K.
  • Gabriele Turchi
    May 2, 2012 at 3:00 pm
    i have the same issue ,
    i talked to BMD about … hopefully will be fixed ,
    please as many as feel that because of that function is not possible to use copy paste (because you cannot export handles than (because create a keyframe on the first frame of the edit )) please post it here , so hopefully they will change it
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX470
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
    Ultrascope
  • Brandon Thomas
    May 2, 2012 at 3:12 pm
    My solution has been to show the node tree, and drag and drop the node i want.
