Anyone ventured into IE 9 yet?
Posted by Al Bergstein on March 18, 2011 at 6:53 amAny known incapabilities, not that there should be?
It appears that if you do install, you can’t run side by side with IE8, but can uninstall and it theoretically restores your IE8 without having to reinstall it.
Alf
Al Bergstein replied 15 years, 4 months ago 1 Member · 1 Reply -
1 Reply
Al Bergstein
March 24, 2011 at 9:26 amI’ve done some research on this, avoid 64 bit IE 9 as there are substantial compatability issues. No Flash or YouTube support, apparently. Relies on activex controls. From this week’s Windows Secrets,
WOODY’S WINDOWS
Internet Explorer 9’s nagging 64-bit woes
By Woody Leonhard
64-bit computing is now mainstream, but the world’s most commonly used browser, Internet Explorer, didn’t get the memo.
You now have a 64-bit system and are running a 64-bit OS, but that doesn’t mean you want to run 64-bit IE 9. Here’s why.
Personal computing migrating rapidly to 64-bit
If you have a relatively new PC loaded with 4GB or more of RAM, chances are excellent that you’re running 64-bit Windows 7. (Sixty-four-bit is a prerequisite for using more than about 3.6 GB of memory.) Even if your PC isn’t so well endowed with memory, there are good reasons for using 64-bit Windows: improved security from forced driver signing, for example, rings quite a few chimes. Sooner or later almost everybody will be running 64-bit. It’s inevitable.
Many of the earlier problems with 64-bit products, such as big-name apps, are steadily disappearing. There’s been, for example, an enormous jump in the number of stable 64-bit drivers — no doubt in response to the surge of 64-bit Windows 7 installations.
All of which makes IE 9’s poorly implemented 64-bit version so puzzling — as is the impression that Microsoft, in general, is far behind the 64-bit migration curve.
A plethora of 64-bit compatibility problems
IE 9 (64) has a hard time fitting into a 32-bit world. Here’s why.
Internet Explorer works with ActiveX controls, small apps that hook into the browser and run on your computer. (Firefox, Chrome, Opera, Safari, and most other browsers don’t use ActiveX.) Almost all of the ActiveX controls in the vast Internet cesspool … er, ecosystem, are 32-bit.
Unfortunately, IE 9 (64) can’t use 32-bit ActiveX controls. That means all sorts of popular programs effectively get the axe. Adobe Flash, for example, won’t run on IE 9 (64). Try viewing a YouTube video with IE 9 (64), and you’re greeted with an admonition: “You need to upgrade your Adobe Flash Player to watch this video.” Click to download Flash, and you get the warning: “Flash Player 10.1 is not currently available for Internet Explorer 9 (64-bit).” Adobe does have a test version of Flash that plays occasionally on IE 9 (64), but I wouldn’t bet the farm on it.
I think I’ll stick with Chrome & f.f.
Alf
