Activity Forums DaVinci Resolve Anyone using the IOfx card to boost Resolve?
  • Anyone using the IOfx card to boost Resolve?
    Posted by Singleton Makin on April 21, 2014 at 6:51 pm
    I posted this in the smoke forum as I’m trying to get all software users advice or if in fact this IOfx card is in use anywhere
    Thanks in advance
    Singleton
    Sir
    Finally I found an ad on your product after hearing about it in another press release
    Can you tell me which product or is the IOfx cards the best solution for running Aurodesk Smoke or Flame or Foundry Nuke
    Adobe After Effects
    Avid or Final Cut Pro?
    I know I listed a lot of apps
    But my main concern is the order I gave you
    I have been wanting to build a PC or Hackintosh ( since the new Mac has no PCIe slots
    This was supposed to be ( your product) the best solution to add to multi-core or single core i7 processor builds
    I know GPU nVidia cards get rated by autodesk tested with their products
    But never this
    Can you tell me how this helps
    I understand it to be like flash RAM is this correct
    In the past I think all a autodesk flame software had to have such hardware but since the processors have quadrupled and the internal gpu these basic systems run as fast as the older with hardware
    But my goal is to invest into the fastest ONLINE system I can for 4K online editing
    Thanks for your information
    Jsm
    Singleton Makin
    “observe the masses and do the opposite!”
    Singleton Makin replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
