Activity Forums Audio Anyone using the Edirol R-4 Pro?
  • Anyone using the Edirol R-4 Pro?
    Posted by Leigh Harrington on September 19, 2007 at 8:46 pm
    Hello all,
    I have an Edirol R-4 Pro field recorder that I am planning to use for a shoot this weekend. I haven’t had, and will unlikely have, much time to play around with the settings before the shoot. I’m especially concerned about how well the files from the R-4 will import into my editing system — Vegas 6 or VT 4.6. Anyone have any tips regarding 16 bit vs. 24 bit audio, 29.97 vs. 29.97D timecode. Also, the manual said that by recording 4 channels of audio mono the WAV files from each mic will be saved in a pjt file? Never heard of this one, will it play well or will the computer/editing programs fail to recognize it? Any advice?
    Thanks in advance
    David Raphael israel replied 18 years, 11 months ago 2 Members · 1 Reply
  • David Raphael israel
    September 25, 2007 at 2:37 am
    dil —
    I don’t have / haven’t used the gizmo . . . but I’ve read a bit about it, and one (perhaps obvious) interesting feature is the fact it can accept (& synch to) timecode generated by your camera — IF you have a camera that generates such. Of course many cameras don’t.
    Otherwise — I assume it’s smartest to set the timecode to whatever your camera is set to 🙂
    Also — somebody lately advised (about doing digital audio recordings of this sort), to use a clapper board, as good way to establish synch when editing.
    You might want to ask on the Vegas forum about the audio-file format question . . . though perhaps somebody will peep up here.
    cheers,
    d.i.
    david raphael israel
    bhopal, india
