Activity › Forums › DaVinci Resolve › Anyone using Lightspace CMS & LUT Buddy?
  • Anyone using Lightspace CMS & LUT Buddy?
    Posted by Mel Matsuoka on August 30, 2012 at 7:25 pm
    I’m getting a Lightspace CMS system for display profiling and calibration/display-LUT generation (I’m going to use the calibration LUT as a Display LUT in Resolve), and was wondering if anyone has successfully used the “LUT Buddy” plugin from Red Giant to load in 3D calibration LUTs from Lightspace?
    Until Blackmagic fixes their inaccurate & broken HDLink Pro product, I don’t have an outboard LUT box that can globally calibrate the signal out of my Decklink card. So while the Lightspace LUT will work as a calibration/display-LUT out of Resolve, it doesn’t do me any good for FCP/Premiere Pro/AE playback, which I need to play back my Resolve grades for final online conform. I was hoping LUT Buddy would work for this purpose (obviously for playback purposes only…I’d disable it for file & tape output).
    Steve Shaw replied 13 years, 7 months ago 3 Members · 3 Replies
  • Steve Shaw
    August 31, 2012 at 8:39 am
    Hi Mel,
    As LUT Buddy says it works with 3D LUT (standard .cps and .cube formats) it should all just work (as we have discussed separately via e-mail).
    But, if the formats are in some way different we will add them, as we do on a regular basis for customers who find new formats.
    So there really should be no problem.
    Cheers,
    Steve
  • Shian Storm
    February 10, 2013 at 5:40 am
    I can import 3D .cube LUTs created in Davinci into AE CS6 using it’s Apply LUT function, but cannot import that same .cube LUT into anything support by LUT Buddy. It doesn’t recognize any of the LUT’s exported from Resolve 9.
  • Steve Shaw
    February 10, 2013 at 10:15 am
    You will need to convert the LUT format – the Main Component of LightSpace CMS can do this.
    Steve
