Activity › Forums › Apple Final Cut Pro Legacy › Anyone using eSATA connection on macpro
Posted by Jason Brown on October 19, 2009 at 4:17 pmHey Guys,
I’m trying to setup the LaCie big quadra (8TB) on my final cut system.
I had an eSATA card put in…but I can’t get the drive to come up. In disk utility it doesn’t even come up as a drive attached. If I use Firewire 800 it does…but I’d like the speed from eSATA.
I went through the instructions on the card (HighPoint eSATA controller) and setup the ARRAY through web interface…but it’s not coming up on my MacPro.
Any ideas? Do I just have a cheap eSATA controller?
-Jason
Niklas Wikman replied 16 years, 7 months ago 11 Members · 18 Replies -
Shane Ross
October 19, 2009 at 4:39 pmInstall the latest drivers for that eSATA card?
Shane
Read my blog, Little Frog in High Def -
Alex Elkins
October 19, 2009 at 4:51 pmHi Jason,
If you go to the Apple Icon> About This Mac > More Info… you should be able to see your card listed under the PCI Cards menu. If you select it the info pane will tell you whether or not the driver is installed. If it says ‘No’, you could probably find the driver on the Highpoint support site (or on a CD that came with the card??).
If it says ‘Yes’ then you have a problem. Could be one of many things, in which case I’d contact Highpoint and Lacie and see what their tech people recommend.Good luck,
Alex Elkins -
Jason Brown
October 19, 2009 at 4:54 pmYea…driver installed and updated…still not working.
Just wondering if there was anything special to it. I’ve never used the eSATA protocol before…so this connection type is new for me.
-Jason
Christopher Wright
October 19, 2009 at 6:12 pmIf you are working on Snow Leopard, then many of the eSata drivers are not working yet.
I was fortunate that the GspeedEs drivers were updated for SN and my Raid array finally is working fine again.Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
Nehalem Octocore 12 GB Ram, Nvidia card, MBP, MXO, MXO2 mini, Windows Vista Adobe Studio CS4, Vegas 9.0, Lightwave 9.6, Sound Forge 9, Acid Pro 7, Continuum 6, Boris Red 4, Combustion 2008, Sapphire Effects -
Jason Brown
October 19, 2009 at 6:49 pmStill on OSX 10.5.8
Here’s a quick question…I’m new to macs and don’t understand the OS numbering system.
If Snow Leopard is a new OS, wouldn’t it be version 11.
From what I’ve seen…it seems to be 10.6. Which would indicate to me that it is just an upgrade step in a software’s evolution. So is Snow Leopoard just an update to Leopard?
I’m speaking completely out of context because I’ve only been working on mac’s for 3 months.
-Jason
Walter Biscardi
October 19, 2009 at 8:49 pm[Jason Brown] “If Snow Leopard is a new OS, wouldn’t it be version 11.
“No, all of OS X has been a point upgrade.
10.3 was Jaguar. 10.4 was Tiger. 10.5 Leopard, 10.6 Snow Leopard and so on.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital. -
Michael Gissing
October 19, 2009 at 8:57 pm[Jason Brown] “So is Snow Leopoard just an update to Leopard?”
Who knows how OS people work out the numbering. The common protocol has been that fundamental changes jump whole numbers. Going from OS9 to OS10 was totally a new OS as they went to Unix. Leopard and Snow Leopard are a continuation of that, with Snow leopard dropping support for non intel chip computers and adding 64 bit support.
Then of course there are the marketing people who come up with jazzy names like Tiger and Snow Leopard.
Regarding your problem, there were some fairly recent threads warning of a lack of Snow Leopard support for a particular chip on many esata boards and that there was a lack of drivers.
https://forums.creativecow.net/thread/8/1051087#1051087 -
Eric Johnson
October 19, 2009 at 10:20 pmYou may want to find out if LaCie of Highpoint even support each other. There are some cards that just don’t speak the right eSATA for certain drives. And in other cases, using the card manufactured by the drives OEM will provide features above and beyond other cards. An example would be G-Tech. They have their own drive maintenance/monitoring software that can only be used if you are using their eSATA card with their drives.
That’s not to say you can’t mix and match, I use both LaCie, G-Tech and Sonnet drives with a Sonnet card. But that doesn’t mean they are all interchangeable.
Jason Brown
October 19, 2009 at 11:22 pmThat’s just coming from my Windows background I guess.
What would version 11 constitute? Is that just after 10.9? Or what would constitute a jump to the full number?
-Jason
Tom Matthies
October 20, 2009 at 2:27 amNot running Snow Leopard yet (it’s sitting on the shelf waiting) but when I changed my eSATA drives over to my MacPro, I not only had to install new drivers but also update the firmware on the card before it worked properly. I’m running Firmtek products. Just a thought.
TomLife moves pretty fast. If you don’t stop and look around once in a while, you could miss it.–Ferris Bueller
