Activity Forums VEGAS Pro Anyone using an XHA1 with Sony Vidcap??
  • Anyone using an XHA1 with Sony Vidcap??
    Posted by Willie Bobo on July 7, 2010 at 6:00 pm
    It seems to be recognized alright but I get : ” The device Canon XHA1 could not be opened. Please make sure it is turned on and not being used by another application or user.”
    Any thoughts?
    Thanks very much,
    Randy
    John Rofrano replied 16 years, 1 month ago 2 Members · 3 Replies
  • John Rofrano
    July 7, 2010 at 8:22 pm
    The Canon XHA1 is HDV and Sony Vidcap is an SD capture tool. If you really want to capture SD then make sure that the Canon XHA1 is in DV downconvert mode. Otherwise you need to use the HDV capture tool within Vegas.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Willie Bobo
    July 7, 2010 at 10:16 pm
    Why would it ask me me if I want to capture SD or HD when opening then?
    I would capture in HD and then downconvert but I’m having to match some 4:3 footage
    Can you tell me where that is in V8 please?
    Thanks John,
    Randy
  • John Rofrano
    July 8, 2010 at 2:32 am
    Vegas will ask you if you want to capture HD or SD and then either use the internal HD tool or the external SD Vidcap. You said you were using Vidcap so you must have told it you want to capture SD.
    Not a problem. Just make sure that your camera is in DV downconvert mode and use Vidcap. If it’s in HDV mode, Vidcap will not be able to capture from it.
    File | Capture Video… and then select HDV or SDI.
    ~jr
