Anyone updated to 2.1.3?
Posted by Jim Wiseman on April 17, 2013 at 8:17 pmAnyone updated to 2.1.3? If so, how is it performing?
Jim Wiseman
Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIeBob Slenker replied 13 years, 5 months ago 5 Members · 10 Replies -
Jeremy Rowell
April 17, 2013 at 9:03 pmI have “Updated”. I can see no difference. Everything is working ok.
Jim Wiseman
April 17, 2013 at 9:24 pmThanks. Glad to see they are keeping up to date with new I/O hardware and OSX system software.
Jim Wiseman
Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe -
Floh Peters
April 18, 2013 at 11:54 amYep, not much happened except support for the new hardware (which of course is great). Have been working with it for a couple of weeks without (new) issues.
Jaeson Koszarsky
April 18, 2013 at 4:21 pmI was hoping to see the “exiting from RED freeze” bug get fixed. I find myself force quitting M100 daily. It happens on both our MacPro systems.
Jaeson
Jaeson Koszarsky
April 18, 2013 at 8:53 pmWhat version of AJA driver is needed for Suite 2.1.3? I didn’t read anything in the release notes that mentions needing to update. So I installed 2.1.3, it went ok. Launched Media100 and was greeted with:
“Could not start the application because an incompatibility with the AJA hardware driver was detected.”
For AJA, I’m currently using 10.3.2 with KONA LHi. I see v10.4.4 on the AJA website. Is that supported by Suite2.1.3?
Jaeson
Bob Slenker
April 21, 2013 at 3:21 amI upgraded today on a MacBook Pro and oddly now the app won’t work. It opens but goes straight to the “About” window showing the registration info. All other controls are grayed out and I can’t even close the app without a force-quit. I will say that the “About-Registration” panel was the last thing I had open in my previous version. I was looking at the product ID and unlock code wondering if upgrading would require a new one.
I was running Lion but encountered this issue so afterwards, today I upgraded to Mountain Lion wondering if that had anything to do with it. Sadly, no.
Jaeson Koszarsky
April 21, 2013 at 12:38 pmI don’t know if this is what’s happening in your situation, but I’ve gotten stuck with OpenOffice several times after launching the app and needed to delete the “saved state” information before I could use it again.
In this case, I need to hold OPTION key, go to the GO menu, and select LIBRARY. Then look for the SAVED APPLICATION STATE folder. In there would be a file like org.openoffice.script.savedState that needs deleted.
I’ve not had this ever happen with Media100. But if I did, it would be something I’d try.
Jaeson
Bob Slenker
April 21, 2013 at 11:12 pmThanks Jaeson.
i did that. it might have helped. not sure. the app still opened the same way but this time i simply clicked in the license key box where the license key was already listed and i just hit enter and the window closed, opening up the rest of the windows and allowing the app to function properly. chances are i am an idiot and that was all i needed to do. =)
Bob
