Activity › Forums › Avid Media Composer › Anyone think of a better way to do this..?
Glenn Sakatch replied 11 years, 8 months ago 9 Members · 14 Replies
Grinner Hester
December 13, 2014 at 3:06 amif adding nats to every broll shot, you will indeed have to matchframe each one. Shouldnt take too long as you’ll just hit in/out, match on the first frame then just lay nats on A3
if ya give him an omf, he’ll have handles. -
John Pale
December 15, 2014 at 5:02 am[Job ter Burg] “What I usually do is duplicate my sequence, strip the audio tracks, then create a macro that makes an audio cut for every picture cut. I call it “Audio-follows-Video”. I AAF that along with the actual cut. It gives the dialogue editors sync sound to every frame of the sequence, even if it has been replaced by another take. It allows them to steal sighs, sniffs and what not.
“This is actually a beautiful solution. Lets you cut the way you want and gives your sound editor everything he could ever need.
Glenn Sakatch
December 17, 2014 at 4:36 pmInteresting Job. I’m assuming your macro includes a “next edit” and a “repeat” function?
Basically the same as my G13 macro. I wonder if the G13 has a repeat function.
Glenn
Glenn Sakatch
December 17, 2014 at 4:40 pmAs I look at it…I guess that would be the “repeat options” switch.
Glenn
